Turn Signal Problems
  • 965 Views
Offline dectar99
  • 104
« on: February 23, 2012, 07:24:34 PM »
Have a problem with my right turn signal on my 98 tracker, it runs at twice the speed of the left side, all 4  flashers work fine, as does the left side.  The bulbs work ok, there not burned out & it act's  like my Chevy van did when the turn bulb burnt out, so I am thinking it's a ground in the bulb or somewere in the wiring.  Anyone got any suggestions
Offline duncan4x4
  • 30
Re: Turn Signal Problems
« Reply #1 on: February 26, 2012, 01:31:26 PM »
bulbs arent that much id try replacing them anyways and if that doesnt help then try the wiring could be a ground or a loose wire hopr this helps
Offline dectar99
  • 104
« Reply #2 on: February 28, 2012, 07:40:59 PM »
Well got a chance to work on it last weekend, took the front turn bulb out & it looked fine so just put it back in & now it's works just fine, have to keep an eye on it & see if it happens again.
