Coil suspension swa
  • 1397 Views
Offline chriscouto
  • 9
Coil suspension swa
« on: February 23, 2012, 05:56:51 PM »
I am in the process of swapping my 88 tin top sami to coils in the front. I bought some brackets from ballistic fab and after alot of welding cutting and modifying im wondering wheres the best place to find 5.5 " id x 10" springs with 175lbs rate. I have called a few places with no luck. Any info would be great
Re: Coil suspension swa
« Reply #1 on: February 23, 2012, 09:15:01 PM »
That is a really fat spring, are you sue it is a 5.5 ID spring?  The largest I can find is a 4.5 and most kits only use a 3".
« Reply #2 on: February 24, 2012, 07:31:59 AM »
You should find what you are looking for here http://www.poske.com/parts/Hyperco/index.htm?showall=y
Also look at Bronco & Ford Van coils.  With a little research you can find them in the Salvage yards.
Another spot http://www.best-deal.com/search/landing/query/front+coil+springs/s/google/koid/8770389797/gkaid/100832032/adid/4026820792/gkyid/137203158/?query=front+coil+springs&gclid=CITqwa30tq4CFbAHRQodFBBbnw
Also i found an interesting VW site.  I do not know the length of VW springs but a tape measure would tell me.  This has the # rating and color chart so you could tell at a glance what the rating is.
Thanks for the informative question.
« Last Edit: February 24, 2012, 07:40:44 AM by BRD HNTR »
Offline chriscouto
  • 9
« Reply #3 on: February 29, 2012, 08:42:31 AM »
Thanjs for the help guys i found what i needed soon i will be putting pics up soon
