Technical Discussion - Performance / Modify
Carb Question for 1.6 8v swap
SNJSamurai
386
Always have fun in life never know when it can end
February 15, 2012, 06:56:24 PM »
Im in the process in finishing my 1.6 swap in my samurai.
I used the 1.3 intake manifold and I am wondering if a Weber Carb would be a waist of money and I should just keep the stock 1.3 carb?
Thanks
Bob
rbparker
120
Re: Carb Question for 1.6 8v swap
February 15, 2012, 08:19:29 PM »
I use the weber carb with the same set up. I bought a jet pac and tuned it. It gets into the power band by 1900 rpm and keeps building until 4500 rpm. I do have a torque cam and it runs much smother than the 1.3.
Boxcar
936
34
February 17, 2012, 08:05:29 AM »
There is allways this one.
http://www.ebay.com/itm/New-75-76-Toyota-Corolla-1-6-1600-2BBL-Carburetor-/270916269342?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACorolla&vxp=mtr&hash=item3f13de351e
Advantages:
Nearly a direct fit,( no adapters)
Works well off angles, ( Unlike the Weber)
Stock air box,
Jetted for the 1600,
Ultra simple to tune ,
At $95 , less than half the cost of the Weber,
Great low end gains ,
Better economy than the Weber
Noticeable top end gains.
E, choke.....
....Boxcar...
God Bless
Rhinoman
4502
36
Bend it, Break it, Fix it
Reply #3 on:
February 18, 2012, 02:43:56 PM »
The Weber will give a lot more power, the stock 1.3 carb is quite restrictive on the 1.3 and more so on the 1.6.
http://www.rhinopower.org
SNJSamurai
386
Reply #4 on:
March 15, 2012, 01:15:57 AM »
Sorry about the really late replies guys. School, Work, Etc.
I read on ACKs about the toyota carb but it was a little confusing. Is there a better explanation?
Thanks
Bob
bentparts
4536
60
I'd rather be Blown AND Injected.
Reply #5 on:
March 20, 2012, 04:25:58 AM »
Why didn't you use the fuel injection that came with the engine?
Boxcar
936
34
Reply #6 on:
March 20, 2012, 09:22:11 AM »
What do you need to know about the Toyota swap?
Ask and you will receive...Boxcar...
God Bless
GO_OUTSIDE!
182
Sammy Jack
Reply #7 on:
August 17, 2012, 05:21:59 AM »
Boxcar, I sent you a PM.
I am very much interested in putting a corolla carb on a 1.6L 8V in my Samurai. Actually I would like to put it on my 1.3L until I can find a 1.6L and then do a full swap. Is that a possibility?
Whats a guy gotta do to earn some respect around here?
GO_OUTSIDE!
182
Sammy Jack
Reply #8 on:
August 17, 2012, 05:32:54 AM »
I found these on ebay
Will it work or does it have to be a 1976 77 carb? They are both for the 2TC engine.
GO_OUTSIDE!
182
Sammy Jack
Reply #9 on:
August 19, 2012, 02:29:06 PM »
I found a '76 2tc carb on ebay. Its on its way, any help would be appreciated.
