Corola carb swap
  • 16 Replies
  • 6519 Views
Offline Boxcar
  • 936
Corola carb swap
« on: February 12, 2012, 01:57:50 PM »
After much research I decided to go for the Yota carb over the CV and the Webber.
 First because of the ease of install. Almost no mods to the Zuke.
 Cost. $99 New from a vendor found on E Bay.....
Took 1 hour to do the entire conversion and we were off to the woods for a test drive.
 Worked flawless .
Steep angles were no problem. Fires up effortlessly. Great torque out of the whole. Descent top end increase.
 I gotta tell you. If your looking for a good swap for that pos Hitachi. Some times old school is best...
 You will get better top end from the Weber, But big angles will be an issue.
The CV conversion works great, But at $400 . I don't See the advantage over the Yota.
The carb we used was the last version of the 2bbl used on the Corola 1200cc engine 1978 ish.
NO MODS REQUIRED to bolt in place of the Hitachi!!!!! And using the stock Zuke air box.
Had to convert the throttle cable to ball fitting , and fab a cable mount for the throttle and choke cable. That's it....Boxcar...
God Bless
Re: Corola carb swap
« Reply #1 on: February 20, 2012, 08:14:10 PM »
What did you do with all of the emission connections? Did you notice any improvement with gas mileage, and overall driving in town. Looks like a good swap, and easier than the others.
Offline Boxcar
  • 936
« Reply #2 on: February 20, 2012, 08:22:35 PM »
Removed everything ....Plugged unused vacuum ports.
5mpg increase.
 Runs like a different rig....Much improved.....Boxcar...
God Bless
Offline Divn4$
  • 18
« Reply #3 on: February 21, 2012, 01:02:20 PM »
Hey Boxcar,Do you still have the info on the guy who has the Corola carbs? Think thats the way I want to go,Seems like it will work great for what I want to do.
I'm Disapointed
 We were supposed to have flying cars by now...
Offline Boxcar
  • 936
« Reply #4 on: February 21, 2012, 01:15:39 PM »
http://myworld.ebay.com/robbob36/
Here ya go....Boxcar...
« Last Edit: February 21, 2012, 01:18:26 PM by Boxcar »
God Bless
Offline Divn4$
  • 18
« Reply #5 on: February 21, 2012, 02:01:05 PM »
Thanks, Boxcar
I'm Disapointed
Offline 87zeus
« Reply #6 on: April 22, 2012, 11:20:45 AM »
I just did this swap yesterday after reading the post last week. It seems to have more pep in its step but the olny problem I am having is the idle is way eratic. I cant find a vaccum leak, checked the timing. has anyone else had this problem? If so whad was the solution?
Offline Boxcar
  • 936
« Reply #7 on: April 23, 2012, 12:21:29 PM »
Probubly the base gasket...Boxcar...
God Bless
Offline FBJR
  • 99
« Reply #8 on: April 23, 2012, 08:03:54 PM »
Spray wd-40 around the base when running. If it smooths out that is it.
I think I had a motorcycle that was heavier!!
Offline Boxcar
  • 936
« Reply #9 on: April 24, 2012, 12:17:51 PM »
That's not exactly what I meant. The base gasket needs to be modified to fit the vacuum port on the new carb.
 I think I have a gasket that was modified for the Yota carb laying an a bench at my shop.
I will take a picture of it and post it later....Boxcar...
God Bless
Offline dngrs1
  • 15
« Reply #10 on: May 29, 2012, 06:05:33 PM »
Thought I would revive this thread as I took the advice of Boxcar and ordered the yota carb from the ebay seller mentioned above. Um, I think he sent the wrong carb. What I got is a Motorcraft 2 barrel progressive carb that will not even come close to mounting on the Samurai. The bolt pattern is larger and the venturi's are much larger. I ordered a 2 barrel carb for a '78 corrola with the 1200cc motor. I don't know what this carb fits but I am inclined to keep it as I may find some use down the line.
 Boxcar, do you happen to have the part # of the carb you ordered from robbob36 from ebay? Thanks.
Offline dngrs1
  • 15
« Reply #11 on: May 30, 2012, 12:33:12 PM »
After doing a bit of research I found that the Ebay seller sent me a Holley R-6666-1 two barrel carb that fits mid 70's Ford and Mercury 2.8L V-6's. These carbs are listed for 2 1/2 times what I paid. Hmmmm.
I can't seem to find the corolla carb I wanted, anywhere. Looks like I'm back to square one.  :(
Offline Boxcar
  • 936
Re: Corolla carb swap
« Reply #12 on: May 31, 2012, 07:34:32 PM »
Sorry I haven't been watching this site for a while.  Not enough time in the day. I'll look up the # for ya tomarow....Boxcar...
 PS: Call the seller , He posts his # and sends it with the carb. He will make it good as long as you ordered the correct carb...
God Bless
Offline Boxcar
  • 936
« Reply #13 on: June 01, 2012, 07:32:34 AM »
Aisan carb #21100-24010 or #21100-24020. They are getting hard to find. I'm glad I bought a few of them...
 I will look for a newvendorr and post what I find...Boxcar...
PS: This site lists the carb in stock. I have no exp. whith this vendor....
http://www.carb-x.com
« Last Edit: June 01, 2012, 07:37:15 AM by Boxcar »
God Bless
« Reply #14 on: June 03, 2012, 10:52:29 PM »
Ive done this swap worked great. You can also use a toyota Starlet carb.Just a little bigger than the corolla carb.But also works good.
