Yep..
The carb is a direct fit.....Only mods were : throttle cable and choke cable mount.
Factory jetting was spot on .
http://www.ebay.com/itm/320842839140?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649Front of engine bay:
I also run a Calmini ceramic coated header, NON cat 2" exhaust with flow master. Run it all the way out the back (stock location)
You should have no problem spinning those tires.
If you need it I'd be happy to send you a schematic of the vacuum locations (all three of them)....Boxcar...
BY THE WAY: it's not a bigger carb. It's a 28x28cfm square boar carter design carb. It's just way, way more efficient at making hp....
I've never been a fan of the 1600 Zuke swap.
By the time you factor in the time, the weight gain, the computer and all that goes with it, the adapters needed to make the swap
and the cost. IMHO it's a bad investment, For the limited amount of hp and torque gains.
Properly camed and set up the 1300 can make enough power at whatever rpm you need the power at. Mine makes most of its power in the mid rainge. Realize of course that I'm completely re geard, have ported my head and done some valve magic to it as well, along with the carb and exhaust swaps. And am running a larger tire than you plan on running. I have no problem running down the highway, in Oregon. Can you say "not flat"?
If all you want is freeway speed and economy. Run a cam that makes power between 3 and 5000 rpm s. Feed it fuel (efficiently)
and exhaust it (efficiently) And problem solved...Sorry for the rant .
