Check Engine Lights is on
  • 1181 Views
« on: February 08, 2012, 04:41:04 PM »
Trying to figure out where to start hope you guys can help me
My check engine light came on, so i checked and it is say code 52 which is fuel injector so now i know that where do i go from here, is one of my injectors bad or cloged and how do i find out if so
Its a 95 zuki kick 1.6 16v
95 kick 2dr 2.5 lift springs and 31 kumho m/t
Re: Check Engine Lights is on
« Reply #1 on: February 09, 2012, 07:59:56 AM »
check the injector harness in the area IT plugs into the eng. harness the metal harness wrap they use may have chafed in the injector harness.If all good test the injectors
« Reply #2 on: February 09, 2012, 07:08:32 PM »
With a multi-port injection you can hit the injector with 12v and you should hear it click.  If it doesn't click, it's broken and you need to give Trail Tough a call and see if they have any used ones.
Whatever you do, DON'T do this on an 8v with the throttle body.  You will toast the injector.
« Reply #3 on: February 10, 2012, 04:53:58 AM »
Thanks ill try those and let you all know what happens
« Reply #4 on: February 10, 2012, 01:37:22 PM »
I would suspect a leaking injector. Check the colour of the spark plugs, it should be easy to determine which is the problem cylinder.
