boxcar, You're the man!
Thanks a ton for the info, This is why I posted here... greatly appreciated.
I'll get under it tonight and measure the springs to verify. I'm trying to put together a "parts list" so I can tear into it and put the finishing touches on it. I know the front axle needs rebuilt (seals), needs new shocks (running ranchos with only 5" of travel), needs longer brake lines, plus the pinion angle shift and driveling change you mentioned, no sway bar on the front or back - should I run both or just the rear, and why?
This weekend was the first time I've torn into it, In the process of going through all the wiring, accessory wires everywhere... It was broke into and they pulled the radio face out with all the switches. I've got the winch up and running, the push button starter in order and most of the lighting wires figured out... now it's time for the mechanical piece!
