Technical Discussion - Performance / Modify
1.6 8v punch out
1.6 8v punch out
TxBoi
6
95kick 2wd
1.6 8v punch out
February 04, 2012, 07:46:33 PM »
Looking for info on cylinder size on 1.6 8v so I know wher e to start to bore out .30 over or if its safe to go 40. And also wat else may be involved. Also in the plan is a high range cam. Any ideas on a good one? Thanks
95 kick,2dr,2wd,5spd,sft top.
Texan by chance, American by the grace of god!
bentparts
4536
60
I'd rather be Blown AND Injected.
Re: 1.6 8v punch out
February 05, 2012, 05:50:07 AM »
Standard bore is 75mm ( 74.977) 40 over pistons are offered by the aftermarket. Check out Low Range, TrailTough or any of our vendors for cams.
TxBoi
6
95kick 2wd
February 05, 2012, 01:41:41 PM »
Thank you very much. Now ihave a starting point.
Safari-Tracker
16
Reply #3 on:
February 05, 2012, 06:54:12 PM »
How far can you overbore before you run in to trouble.
