budget lift geo ???
  • 2864 Views
budget lift geo ???
« on: January 27, 2012, 01:27:52 PM »
 I was reading a post on here the other day about a budget lift using explorer springs in the front and cherokee springs in the rear the guy was very thorough on his description and thought what a great way to go. So I aquired all parts to do this but then realized I recieved front springs from a cherokee , called the junk yard they say no rear springs on a cherokee at least not coils . In the gentlemens posts it says use rear coils off a cherokee early 90's model did he mean use the fronts ? Any help would be greatly appreciated I'm building my first geo for my son and need some direction THANKS !!!!!!
Offline mike5721947
  • 545
Re: budget lift geo ???
« Reply #1 on: January 27, 2012, 07:54:00 PM »
cherokee was always coil front and leaf rear suspension.
your thinking of the GRAND cherokee. 93+ pre 93 was the same as the cherokee post 93 switched to coils all around.
it is rear coil springs. for a 93+ jeep grand cherokee
31" kumhos 3inchs of lift.
Offline KJMac
  • 280
« Reply #2 on: January 29, 2012, 09:04:59 PM »
I used jeep LJ  front springs on the back and Ford ranger on the from that I had to cut the pig tail on the one end. The back was a lot higher so I used spacers. I then moved the front forward 1" and dropped a-arm and diff brackets, it then needed a little more spacer on the front. It is a touch soft but rides nice and the back is stiff but I plan on moving the rear back 1", I figure that will soften it up!
If you have questions just ask.
Kevin
Offline CodyB
  • 16
« Reply #3 on: February 02, 2012, 05:31:12 PM »
What year of explorer springs did he use?
Offline Scotsmn
  • 29
« Reply #4 on: February 02, 2012, 06:31:36 PM »
Figured I would add the link to the to actual write up - http://www.zukiworld.com/forum/build-diaries-how-to-diy/90-tracker-with-budget-lift/
I used 93 or 94 explorer springs for mine, but any of them from 91 to 94 are the same in the explorer and 4x4 rangers.
Sold - 1990 Geo Tracker 2dr soft top - 3" homemade spring lift
New - 1992 Sidekick 4dr 16v manual - working on lift and motor
