lockers + ice?
  • 1793 Views
Offline 90Stomper
  • 427
lockers + ice?
« on: May 02, 2004, 03:30:50 PM »
thinking of getting some lockright lockers for the rear in a month or so and have a few Qs...
if i get now can i change gears next year and use the same lockers?
if i get the lockright ones what is going to happen to my light car on an icy highway curve at 40 mph when one wheel slips?  ganna lock up and push me straight over the curve? ???
where is the best place ($$$) to get them and am i looking for a geo rear or is there another one i am looking for that fits my 90 tracker?
thanks
2004 chevy tracker, 4door, V6
says 'Chevy' on the outside,
Offline explosivo
  • 3157
Re: lockers + ice?
« Reply #1 on: May 02, 2004, 04:16:03 PM »
Hey, just look at it this way: If the locker does force you off the road, it will allow you to drive through the snow and right back onto the road :)
omghi2.us[/url]
Re: lockers + ice?
« Reply #2 on: May 02, 2004, 04:20:21 PM »
Lockers + Ice = Corner Carefully
Offline snakeman
  • 274
  • Alrighty Then
    • Oregon Trail 4x4 Association
Re: lockers + ice?
« Reply #3 on: May 02, 2004, 05:02:55 PM »
thinking of getting some lockright lockers for the rear in a month .......use the same lockers?.......to get them and .........
If your only getting for the rear, you only need one! Yes you can change gears and still keep your locker.
Just drive like your on ice, carefully, and you should be fine.
Jeff
Oregon Trail 4x4 Association - Eugene, Oregon
http://www.ot4x4.org/[/url] Come check us out if your in the Eugene / Springfield area!
87 Tin Top, 1.6 16v, 4.9, 4.62's w/ sidekick rear, TT YJ swap, custom snorkle.
Offline explosivo
  • 3157
Re: lockers + ice?
« Reply #4 on: May 02, 2004, 05:40:37 PM »
How does an auto locker in the front affect steering? Does it handle the same, or is there added resistance? What about an LSD?
omghi2.us[/url]
Offline extremekickin
  • 61
  • GO ZUKI OR GO HOME!!!
Re: lockers + ice?
« Reply #5 on: May 03, 2004, 10:12:50 AM »
An LSD is a good locker but if your front housing and third member are cast it will through tne pinion through the side of the carrier. good web site. www.k9rdj.co.uk
take a look good info on locker problems with the front ends.
1990 1.6L 8V kick,2.5" body and 2.5"sus lift,pro9000 ramsey winch. Full skids,30X9.5 mud kings,15X7steel wheels.Removable doors, Zuki Swift seats,Hi-lift,Steel rear bumper,Electric fan,K&N filter.
Re: lockers + ice?
« Reply #6 on: May 03, 2004, 10:26:04 AM »
The problem with lockers is not the front, unless
you are in 4WD, the problem is the rear will spin
both tires on ice, and very easily I might add, which
will put you into a spin very quickly in a Short Wheelbase
SideKick or Sammy.
In 4WD the front wants to plow straight and not turn
on ice, snow or mud.
Offline 90Stomper
  • 427
Re: lockers + ice?
« Reply #7 on: May 03, 2004, 01:14:35 PM »
thanks all!  have to think some more....
always lookin on the bright side!  gatta like that ;D
