Setup:
Hello all I have a new-to-me '88 Samurai Tin Top with a homebrew SPOA with stock springs + add-a-leaf. The ride is unbearable, I took the add-a-leaf out and no really change in ride, crappy shocks off a Astro-Van is what previous owner told me. Anyways after a ton of
research surfing web, and a really informative call to Dan at LowRangeOffroad.com helped me figure out that what I want is SPUA with OME Dakar springs and a TT Rears-Up-Front Kit to get to my goals of on road comfort and stock reliability with only very occasional offroad/trail riding use.
Issues:
Previous owner hacked off stock perches and welded them back on the top. Given how hackishness(<not a word) everything looks I don't know I trust the positioning of the spring perches currently to use them as a guide to weld the new ones on. I have read until my eye's hurt and I either am to dense to get it or there is not enough visual aids for me understand
Won' the TT RUF kit set the correct castor? Am I correct in that it positions axles using the spring perch pin/bolt (The one goes through the springs and seats in the hole in the spring perch)? I have taken a couple of days and I can't find a single 4x4 shop in Asheville or surrounding areas so I can't even find anyone to pay who I would trust to do it right.
I understand you use angle finder to determine pinion angle but, unless I am visualizing it wrong, don't you have to have the correct springs mounted with load on the axle to determine that angle? If you do it while your suspension is unloaded when you compress it for your normal load the angle will change correct?
Is there any kind of guide/how-to with lots of pictures to determine proper/stock pinion angle? I've read most all of Ack's driveline faq's and I have read countless posts but still am having problems wrapping my brain around this.
Any help or suggestions would be greatly appreciated!
Media:
Overview
Shaky cam explaining problem
Wheel off and steering sway bar overview
