Lots of differentials! Steel and aluminum!
  • 10 Replies
  • 2676 Views
Offline entities
  • 76
« on: January 04, 2012, 02:05:44 PM »
Several items for sale for Suzukis.
2x Steel differential and banjo housings from Grand Vitaras with 5spds.
$240 + shipping per set of steel housing and differential (both differentials sold with the ring & pinion gears removed as they've been sold, price has been adjusted accordingly)
One set sold, only one left.
1x Aluminum front diff from 1992 Sidekick - 5.12 - 22 spline - housing has broken tab, differential in good shape.
$80 + shipping  SOLD
1x Rear diff from 1999 Grand Vitara with 4.30s.
$60 + shipping  SOLD
-Chad
« Last Edit: February 26, 2012, 07:24:46 AM by entities »
1992 Suzuki Sidekick 8V - 3" Calmini (widened and moved forward)- 2" BL - 31"s - 4.24:1 Transfer Case gears - Rear Lockrite locker
Offline gsherred
  • 112
Re: Lots of differentials! Steel and aluminum!
« Reply #1 on: January 10, 2012, 09:16:00 AM »
Where would these be shipping from and will my 4:88 geard fit in a steel diff.  Would I then need new cv shafts for my 02 tracker.
02 ZR2 K&N filter driving lights in bumper body colored coil covers. Jeff's 2 inch spacer lift.
Offline entities
  • 76
« Reply #2 on: January 10, 2012, 12:20:07 PM »
Shipping from 80923
Yes, your gears will fit into the steel differential, no new CVs required, all mount points and such are the same, just steel instead of aluminum.
-Chad
Offline kreator
  • 634
  • 15
« Reply #3 on: January 13, 2012, 07:56:25 AM »
GOOD MORNING , I dont need the gears just one of the steel housings,  how much ? Thanks for your time.
Offline entities
  • 76
« Reply #4 on: January 13, 2012, 11:07:59 AM »
$150 for one of the steel banjo housings.
-Chad
Offline entities
  • 76
« Reply #5 on: January 19, 2012, 07:57:20 AM »
Bump
Offline MongooseVRX
  • 64
    • M.O.S. forum
« Reply #6 on: January 19, 2012, 12:10:50 PM »
-Chad
Is that the third member too for $150?
1993 2-Door Tracker 1.6l 8v 5-speed manual hubs
Minnesota Overland
Offline entities
  • 76
« Reply #7 on: January 19, 2012, 02:23:39 PM »
-Chad
That does not include the 3rd member.
-Chad
Offline entities
  • 76
« Reply #8 on: January 26, 2012, 08:59:51 AM »
Bump
-Chad
Offline entities
  • 76
« Reply #9 on: February 20, 2012, 12:13:10 PM »
Bump.
-Chad
Offline MongooseVRX
  • 64
    • M.O.S. forum
« Reply #10 on: February 24, 2012, 09:25:12 AM »
PM sent
Minnesota Overland
