Steering Damper help
  • 1619 Views
« on: January 03, 2012, 04:01:59 PM »
Just bought a kyb damper and it does not appear to match at all.  Double checked all the part numbers and it is correct. Does this require relocationof the stock mounting setup?  Any help would be great.
Offline TinTopTom
  • 27
Re: Steering Damper help
« Reply #1 on: January 17, 2012, 01:25:07 PM »
I just tried to order one for my Samurai from my local O'Rielly's... their parts database showed one from Rancho, that uses a stud mount on both ends, the wrong mounting scheme for my '86. I ordered the 'house brand' oem replacement instead, shown to have rubber eyes on each end, which worked perfectly.
I learned all over again, that parts books, data bases, for older vehicles is often wrong
Good luck!
Building stuff is a way of life
Offline Capt
  • 738
  • 28
« Reply #2 on: January 17, 2012, 03:41:46 PM »
2 xxxxxxxx on the On Line Data Bases !!!!
Napa, AutoZone, O'Reileys, etc.........
Must have the same F'd source !!!! Try order  front axle wheel bearings !!!
You'll be BLUE IN THE FACE before you get what you need !!!
CAPT
Offline ebattleon
« Reply #3 on: January 20, 2012, 10:10:01 PM »
That's why I try to walk with the old part...save a lot of grief >:(
Common Sense Absent
Offline lv2fsh
  • 312
  • 19
« Reply #4 on: January 23, 2012, 08:40:55 PM »
I have a Rancho stabilizer on my 87. It works good and is heavier duty than the stock. It doesn't use the stock mounts though. It came with bolt on brackets. I like it.
Offline flanny
« Reply #5 on: February 14, 2012, 05:57:18 PM »
? Where does the oem steering damper connect? I bought a sammy with a homemade lift and removed it. Pictures would be great
91 SAMMY
8" LIFT
33X12.50
4.53 GEARS
FORD 5.0 HO MOTOR WITH TRANNY
Offline Boxcar
  • 936
« Reply #6 on: February 15, 2012, 05:59:55 AM »
The oem dampener is mounted to a stud just behind the front sway bar mount (points down ) and the pitman arm....Boxcar...
God Bless
