Shocks??
  • 2335 Views
Offline jrok90
  • 17
Shocks??
« on: December 22, 2011, 05:29:43 PM »
I have a 1in. or 1.5in. shackle lift and I need new shocks.
would original shocks work or do I need longer ones??
also where do I get the bushings for the leaf springs and shackles??
« Last Edit: December 22, 2011, 05:31:45 PM by jrok90 »
Offline 86samurai829
  • 124
Re: Shocks??
« Reply #1 on: December 23, 2011, 07:10:13 AM »
Offline TinTopTom
  • 27
Re: Shocks??
« Reply #2 on: January 17, 2012, 01:29:14 PM »
I have 1 or 1.5" longer shackles as well... the stock shocks work fine.
Building stuff is a way of life
Offline jrok90
  • 17
Re: Shocks??
« Reply #3 on: January 18, 2012, 06:28:32 PM »
i figured out that I have 1.5in lift (shackles are 3in. longer)
I looked up many part numbers and found some longer shocks.
Offline 02CalTaco
  • 196
Re: Shocks??
« Reply #4 on: January 18, 2012, 07:18:51 PM »
My samurai has some shackle lift (i hate it) about 1.5-2".When I looked into shocks most were for 0-2" lift, they varied in the comp. and ext. length between manufacturer. I put som cheapo Gabriel stock replacements on, they had about the same comp./ext. length as some of the othe brands that said good for 0-2" lift.
Offline jrok90
  • 17
Re: Shocks??
« Reply #5 on: January 20, 2012, 06:51:01 PM »
the rancho shocks for a 1.5in lift have the same dimensions as the stockers. I don't know how they figure that will work.
I am running F-150 shocks on the front and jeep CJ shocks on the back.
Offline ebattleon
Re: Shocks??
« Reply #6 on: January 20, 2012, 09:34:06 PM »
I have a SpOA and run Original in front and E25 Nissan's in the back
Common Sense Absent
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: Shocks??
« Reply #7 on: January 21, 2012, 09:49:26 AM »
It is dependant on the max and minimum shock travel depression / extention during flex. That is why folks are sometimes reluctant to answer questions comcerning shock length.
For instance you can run stock shocks by flipping the plates from side to side  on a standard Spoa. But, if you take it wheeling and fully extend the shocks very often they will fail.
