What kind of gas mileage do you get with bigger tires?
  • 13 Replies
  • 3227 Views
Offline WVzuk
  • 181
« on: December 22, 2011, 05:08:36 PM »
Well I like my new toyo Open Country 225/75s on the stock wheels of my 94 sidekick 4door.  Thye ride a lot btter offroad than my previous worn out 205/75s but I just hope my gas mileage doesn't go to hell :(
I am kind of shocked at how much bigger these look than my worn out stockers.
What kind of gas mileage are you guys getting with similar tires?
1994 4dr Sidekick: 3inch Zukination lift, 30x9.50 mud tires, snorkel, ARB rear locker, homemade bumpers
Offline beagle..t
  • 1239
  • 16
Re: What kind of gas mileage do you get with bigger tires?
« Reply #1 on: December 24, 2011, 11:23:23 AM »
well i got 30x9.5x15 ats and get around 400 kms to a tank with a 1.6 8v 5spd on a 91 tracker
« Reply #2 on: December 25, 2011, 05:03:57 AM »
If everything else is stock probably in the mid 20's.
Offline WVzuk
  • 181
« Reply #3 on: December 25, 2011, 07:16:16 AM »
Thanks for the replys.  This is my first post here. I apologize for putting this in the wrong section.  I'll be more careful with that in the future. :)
« Reply #4 on: December 25, 2011, 03:13:34 PM »
This section is fine.  :)  I get between 25 and 28 mpg with the 235/75 R15 tires on my 96 Tracker.  It really depends on which station I get fuel at and what my average speed is.
Offline Dayton86
  • 35
« Reply #5 on: December 25, 2011, 08:04:36 PM »
235/75r15 aggressive private label mud tires, 1 inch coil spacers, short ram intake, aluminum wheels, and 190 degree T stat.
191,000+ miles, 8v, 5 speed, 2 door soft top.
I have seen a best of about 27 mpg with 24-25 mpg in the winter, 21-23 summer,  being an average depending on if the fuel has ethanol or not and my right foot.
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #6 on: December 26, 2011, 06:48:31 AM »
I can run for 3 weeks |removethispart|@ 5 miles a day 5 days a week in a Sammy with 34" tires... LOL.... or from a full tank all the way to Crap... I think I need some gas in the tank ....  :laugh:
In the Midwest it is commonly between the point of about a $.30 increase from the time before...  :'(
Offline rluka
  • 26
« Reply #7 on: December 27, 2011, 03:06:38 PM »
 Shouldn't the gas mileage improve with bigger tires since you actually go further with each revolution. Or is there something Im missing!!
 Curious minds want to know!!!!
Ron L
Offline Dayton86
  • 35
« Reply #8 on: December 27, 2011, 05:04:54 PM »
Bigger tires mean more weight, usually they are wider and have an aggressive tread pattern so it has more rolling resistance.
Offline albertcrony
« Reply #9 on: December 27, 2011, 09:03:32 PM »
Bigger tires have negligible contribution towards increasing the gas mileage as it require engine to work more to get the vehicle to move.
vpn
Offline tuxblacray
  • 20
    • Tuxblacray Photos
« Reply #10 on: December 28, 2011, 01:26:52 PM »
Yes & No...
I went from 30's to 34's. Steel rims to aluminium rims. My current tire / wheel set up weighs less than the previous. I do have a 1.6 8 V but if the gear ratio isn't changed then it takes more power to turn the taller tires at higher speeds as the vehicle momentum begins to slow against the wind / landscape resistance.
Offline KJMac
  • 280
« Reply #11 on: December 28, 2011, 06:21:00 PM »
We have 10% ethanol in our fuel.
I have 3" lift with 235/75/15 wal-Mart Goodyear wrangler a/t on steel 15x7 black d.
I have a header with 2 1/2" exhaust with cat and straight thru turbo muffler.
When deer hunting in the freemont national forest, I averaged 24.1 mpg at an elevation of 6600ft down to 5000ft..
I have a best of 29.3 mpg and worst of 26mpg highway.
Best 25.8 city down to 20.6 mpg. At 200 ft Elevation.
I'm sure I got worse or better tanks that I didn't record! I think I got 30mpg once but can't remember.
« Reply #12 on: December 28, 2011, 07:14:13 PM »
Anything bigger than a 30 on these things with a bit of lift and mileage really starts to drop. 22 avg on mine. A LOT less when it's making boost, on 32's. Sometimes I wish I'd left it on 235's with a small lift. Probably handle a lot better. Still blown though.  ;)
« Reply #13 on: January 01, 2012, 08:40:31 PM »
I ran 225/75s on aluminum wheels on one of my old 4 door sidekicks (4x4, 16V, 5 speed), and I would get a consistent 27-28MPG.
