Rear diff and speed sensor Q,s??? For mike(again)
  • 1776 Views
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« on: May 05, 2004, 02:10:03 PM »
When you change your stock tracker rear diff for a ford 9 inchs, how do you deal with the speed sensor gear?
How your speedo can read correct speed?????
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Re: Rear diff and speed sensor Q,s??? For mike(aga
« Reply #1 on: May 05, 2004, 02:15:10 PM »
SpeedO gear is in the T-case. Thats the ABS senser. I took mine out when I installed the ARB ;D
Offline Fredo
  • 416
« Reply #2 on: May 05, 2004, 02:26:23 PM »
ok and if your rear end have shity ABS, remove this gear cancel ABS?
Fredo
Offline Fredo
  • 416
« Reply #3 on: May 05, 2004, 02:34:13 PM »
On this page they call this gear (speed sensor gear), look:http://www.izook.com/tech/samurai/drivetrain/swarbseries/trackickarb/trackickarb_2.htm
Fredo
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #4 on: May 05, 2004, 03:05:52 PM »
It's called speed sensor gear because that's what it does. It senses the speed of the rear axle and compares it to the front wheels so the computer can adjust brake actuating in pulses.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline 1bigtracker
  • 3409
« Reply #5 on: May 05, 2004, 03:16:03 PM »
can it be removed without everything going haywire?
stu
« Reply #6 on: May 05, 2004, 04:23:04 PM »
stu
Welllll. Mines out and I can still stop ;D
And with the bigger tires the rear brakes don't lock up on dry pavement (on mine).
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #7 on: May 06, 2004, 02:20:06 AM »
I pulled mine, too.  Haven't noticed any difference.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
