We're discussing vehicles and engines that have been out of production for over a decade, it doesn't matter how dated the discussion is, the information contained is probably still valid, unless it pertains to availability, in which case - parts are harder to come by, and some suppliers may have gone out of business.
The DOHC engine puts out 100 to 113 HP, depending on which one you get - yes - there are more than one.
The DOHC head will fit any four cylinder "G-series block" - G13, G15, G16 - however there may not be pistons for all of these blocks that are suitable for use with the DOHC head.
Now - if I might touch on "best way to go" - the G13B DOHC engine is not considered the "best" way to go by all - many prefer to swap in a G16 - the DOHC will present challenges with the intake, exhaust & cooling system plumbing, the distributor location and the EFI system. It also produces it's power at a higher rpm. The G16 on the other hand, produces virtually the same power as the G13 DOHC but at a lower rpm - it is a well documented swap, and kits can be purchased making it almost a "bolt-in"
"Best" really depends on what you plan to use the vehicle for and if off road use is in your plans, the G16 might be a better fit.
