Tire Size 1993 Sidekick JLX
  • 2289 Views
Offline jkribbs
  • 28
« on: December 14, 2011, 02:10:09 AM »
I was just given a pair of Goodyear Wrangler RT/S 235 75 15 tires .  Would they fit on my 1993 Sidekick JLX 4 door 4X4?  They dont look much bigger than the 16's I'm running now, but I'm afraid they will rub.  Thanks for your help.
Offline kreator
  • 634
  • 15
Re: Tire Size 1993 Sidekick JLX
« Reply #1 on: December 14, 2011, 08:34:53 AM »
they will fit no problem, but you said you have 16 " wheels and will have to get differant wheels.
Offline fuzzy1
  • 350
« Reply #2 on: December 14, 2011, 08:39:34 AM »
I ran my BFG 235's for nearly a year before I put the lift on. Slight rub on the plastic inner fender at full lock, & top of the wheelwell in the rear when flexed. Nothing bad enough I couldn't live with though. This was with 15x7 rims with a 4" backspace.
Non Illegitimi Conterat
Offline Merlin93
« Reply #3 on: December 16, 2011, 06:54:05 PM »
235/75R15 tires are commonly reported to fit the Sidekick without modification.  7" rims are a good choice for this tire size (it's what I'm using (on a Samurai)).  I bought mine locally for around $50 each.  For this tire width, OEM Suzuki wheels are really too narrow, but some guys run 'em anyway.  7" rims ordinarily have NO offset or special backspacing.
Some good wheel info at:  http://www.rsracing.com/tech-wheel.html   especially the backspacing chart.
« Last Edit: December 16, 2011, 06:56:23 PM by Merlin93 »
