I love sidekicks and have wanted to own one for years. When I finally found one I could afford I jumped on it. It is a 1992 sidekick 8v, 2 door, 5 spd, 4x4. I got it for $560. Unfortunately , my sidekick has a lot of problems. The biggest is that it idles really rough. I am going to put a link to a youtube video of the idle so you can see how bad it is. The roughness does go away one you give it a little bit of gas, but it does not run great on the road either. So far I have changed the plugs, wires, cap& rotor, fuel filter, new battery, and have put fuel injection cleaner in it. None of these have made one bit of difference. The check engine light is not on.
So some of the know problems are, it does not have a catalytic converter (it has a glass pack and there is a leak in the pipe),
it leaks oil, it smells like it is burning rich in gas, and it does not like to start in the cold.
I have done all the work on the car myself, but I am a novice and do not understand how to do a lot of testing I.E. compression tests, fuel pump test, and stuff of that nature.
As I said before I really love this car, and I see why you all are so passionate about these things. I want this this thing to be a daily driver that occasionally goes offroading, but I do not have a enough money to take it to a mechanic. if anyone here could give me some advice, I would be most appreciative.
Here is the link to the video
