96 tracker turn signal fuse blows
  • 3321 Views
Offline Jebers53
  • 1996 Tracker
« on: December 02, 2011, 02:54:42 PM »
Turn signal wouldn't work, fuse was blown, jiggled wires by fuse, and after removing screws holding steering wheel cover was able to move the wires leading to the turn signal lever, replaced fuse, worked fine for a week, now fuse blown again.  I suspect a short somewhere in the steering column since when I use the turn signal the entire column under the cover shifts a bit.  All other controls work fine.Thought I would check with y'all before I take on removing the wheel/ disabling air bag... Suggestions?
1996 Geo Tracker 4x4 5 speed manual 2 inch Jeff spacer lift 235/75/15 BFG AT
ZOR front bumper/stinger
2008 Provan Tiger Camper 4x4 on Chevy 3500 HD Duramax/Allison
Offline ebattleon
Re: 96 tracker turn signal fuse blows
« Reply #1 on: December 04, 2011, 03:27:52 PM »
Water in one of the lamps may cause that as well.
Common Sense Absent
Offline z0mb1emutha
  • 38
« Reply #2 on: December 04, 2011, 06:07:59 PM »
sounds like a short in the wiring like u checked! usually water in a lamp will just blow the lamp and eventually ruin the socket!
Offline z0mb1emutha
  • 38
« Reply #3 on: December 04, 2011, 06:09:12 PM »
oh and as far as the air bag goes just remove the fuse disconnect the battery and  unplug the yellow connector under the dash!
Offline Jebers53
  • 1996 Tracker
« Reply #4 on: December 06, 2011, 02:38:03 AM »
Thanks I'll check the bulb connections, bulbs were ok thou.
Offline Jebers53
  • 1996 Tracker
« Reply #5 on: December 21, 2011, 04:13:51 PM »
I checked all the turn signal light and back up connections, both on same fuse ( jiggled the wires with the blinker on) they all look ok. Replaced the fuse again and they all worked fine for a few days then the fuse blew again. Could it be an intermittent short having to do with the back up light? Is there a connection with the tranmission or shifter to the back up lights? If so could I disable it to test out if that is the problem? Thanks
Offline Jebers53
  • 1996 Tracker
Re: 96 tracker turn signal fuse blows (solved)
« Reply #6 on: May 06, 2012, 08:34:50 PM »
Finally got around to replacing all the turn bulbs and back up . Cleaned up bulb socket contacts. No issues since!
« Reply #7 on: May 08, 2012, 09:36:52 AM »
Good to hear you got it working.  :)
