Towing a geo without engine battery or ignition switch
  • 1154 Views
Offline kody
  • 11
« on: December 02, 2011, 11:24:21 AM »
How do I tow a geo without engine or electric
Re: Towing a geo without engine battery or ignition switch
« Reply #1 on: December 02, 2011, 11:31:46 AM »
With a tow Bar.
Offline kody
  • 11
« Reply #2 on: December 02, 2011, 12:26:54 PM »
I have a tow bar.  Do I need to disconnect anything on the geo
« Reply #3 on: December 02, 2011, 05:31:45 PM »
I would pull the rear drive shaft if your going long distance, but if you have a transfers case and transmission in it just take a strap for a motorcycle and pull the front of the trans up where it would normally be and put the transfer case in neutral  and you should be OK I towed one like that for a couple of hundred miles.
