Tires vs gearing question
  • 1209 Views
Offline longarch
  • 61
« on: November 28, 2011, 09:44:32 PM »
I have recently purchased a '92 Samurai which has 33" tires, 4.16:1 transfer case reduction, and 5.13:1 gears. It also sports the 8-valve Tracker swap engine. Top speed in this Sammy is 45 to 50 mph. My question is should I go to the 4.62:1 gears? Is anyone running something similar and if yes, what do you recommend? This Sammy will not be rock-crawled or 4-wheeled hard. I will be using it primarily as a daily driver and for hunting so I need the 60 mph.
Jeff
'94 Tracker W/Hard Top
1.5" Front Coil Spacers - 2" Rear Coil Spacers - 2" Strut Spacers
30x9.50x15 Cooper Discoverer STT's
Calmini Front & Rear Tube Bumpers
Bored 30 Over & Head Shaved
Swapped 4:42 gears for 5:12's
Offline tuxblacray
  • 20
    • Tuxblacray Photos
Re: Tires vs gearing question
« Reply #1 on: November 29, 2011, 02:30:29 AM »
6:5:1 Transfer case gears... puts you back in the game with 5th gear. I have your same woe and am watching all of the classifieds for them....
Offline longarch
  • 61
« Reply #2 on: November 29, 2011, 05:32:39 AM »
Thanks. I should have clarified why I mentioned the 4.62:1 gears. I am running the 5.13:1 Tracker/Sidekick gears and I have another set of 4.62:1 Tracker/Sidekick gears that give me the option I considering. Would the 4.62's help me tremendously with my situation? I am totally unaware of how to calculate that.
Jeff
Offline SnoFalls
  • 1358
« Reply #3 on: November 29, 2011, 07:09:44 AM »
plug in your numbers Here
IMO, the 4.62's would be better for you than the too low 5.12's.
Offline longarch
  • 61
« Reply #4 on: November 29, 2011, 04:48:21 PM »
http://potogold.fortunecity.com/
http://potogold.fortunecity.com/suzuki_rpm_mph_calc.zip
WOW!!! This is one awesome spreadsheet.
Std reduction,  4.62 gears, & 33" tires = 69.8 mph at 4K rpm in 5th gear
4.16 reduction, 4.62 gears, & 33" tires = 62.3 mph at 4K rpm in 5th gear
Std reduction,  5.13 gears, & 33" tires = 62.9 mph at 4K rpm in 5th gear
4.16 reduction, 5.13 gears, & 33" tires = 56.1 mph at |removethispart|@ 4K rpm in 5th gear
Original equipment, reduction, tires & gears = 68.9 mph at |removethispart|@ 4K rpm in 5th gear
A very impressive spreadsheet.......................................................
Jeff
« Last Edit: November 29, 2011, 04:54:32 PM by longarch »
