87 Sammi Carburetor
  • 1018 Views
87 Sammi Carburetor
« on: November 28, 2011, 05:15:31 PM »
Okay folks, I am new here even though I have had my 87 Samurai for about 10 years. I am a retired police mechanic and normally do not have any problems figuring out problems but this one has me stumped.
I went to Smog my Samurai and it failed with a reading of 1.40% CO at 2500 rpm. I rebuilt the carb, replaced the air filter, spark plugs and PCV and checked the timing. It runs like a stripped ape but now the CO readings at 2500 rpm is above 8%.
I guess my question to you folks that have knowledge of these things is: What carburetor should I replace it with? I do a lot of off-roading but also run it around town and on the freeways. I don't want to spend a lot of $$$ but I need it to pass smog tests.
HELP!!!
Offline 02CalTaco
  • 196
Re: 87 Sammi Carburetor
« Reply #1 on: November 28, 2011, 06:35:07 PM »
Where are you located? Here in Cali the stock carb is the only carb that is smog legal.
« Reply #2 on: November 29, 2011, 06:45:41 AM »
I am located in one of the two cities in NV that require smog.
