bentparts - Thanks for the comments. I will keep an eye on the latch but so far it seems to be bullet proof. I will also look into the springs you mentioned. Wow 16.0" ? How much did you cut off ? I have the OME 956's which measure 13.0" according to Low Range Off Road and a 500lb spring rate, they seem pretty tall when installed but maybe that is due to the increased OD of the spring material. I figure I am getting 4" of lift with the spring perch mods as well. If I didn't have the heavy bumper and winch I would not be happy with the ride on the road.
BRD HNTR - It was a relief to have it running again, I ran into a a lot of issues in the end but got it to work. Kinda lost some motivation and forgot to update this build as well.
Front End
I am running the Top Hats off a set of old man emu struts, 2" strut spacers and limiting straps on KYB stock replacement struts (they limit just before the strut bottoms). I think this is killing a lot of my "droop". The CV angle with the diff drop and uncompressed suspension is not being pushed at all, this is probably good from a reliability standpoint but I think I am loosing a bit of performance. The Fox Front Struts (not the coilover) offered by Kreator would let me do away with all this "junk" spacers etc. I am really considering that as an option. I'll post up pics of the underneath ASAP.
I wish I could provide you with more information on the hinge. The one thing I am missing is a lathe, as far as I can tell this would be a challenge to make without one. I was looking at TMR and some US vendors but found a small company in Quebec (good for me as its in Canada)
http://www.ztechfab.com/ and picked their hinge up for $60.00 a fraction of the cost others are asking. To me it looked like a 2.5" by 1/4" wall pipe with the inner edged machined to match the bearing race OD. I will try to get some better measurements tonight.
Drone637 - The rear is on 1994 Honda Accord Coils, they are Moog or some aftermarket replacement bought new for $60.00 a set w/ a progressive spring rate of 200lb. They flex and ride amazing with the aftermarket KYB cavalier rear shocks and have a Ton of droop (this is probably due to the remounted rear shock mount as it is higher up on the axle). When it is compressing however the tire is rubbing the body as the coil begins to bind and the rear shock reaches its lower travel limit. It is still a few inches away from bump stop. I would like it to be reliable so need to figure something out. How do you intend to extend your bump stops ?
