I'm not sure about the timing light, I used my neighbor's timing gun to set the the timing, is that the same as a light? I've only had the Tracker for 20,000 kms, so I don't know if/when the valves were adjusted, it has 400,000kms on it and does burn oil or blow smoke. I will try the valve adjustment on my next days off, thanks for the info, it is much appreciated!!
