Technical Discussion - Beginner / Repair
Please help! Alternator plug missing.
SlinginMud
November 06, 2011, 08:50:45 PM »
Alright so my buddy got a smoking deal on an 87 Samurai but it needs a little TLC. The plug that goes into the voltage regulator on the back of the alternator seems to be missing from the harness. I don't know why someone would cut that off but I went over it pretty well and could not find it anywhere. I was curious if you guys knew what colors the wires were going into that plug? All the schematics I found didn't tell me wire colors. I'm hoping I can find the cut wires in the harness and go cut a plug off at a pick n pull yard or something. Any help is greatly appreciated as we can't keep the battery charged without it! Thanks in advance!
mrfuelish
2862
13
you must have a perception problem.
Re: Please help! Alternator plug missing.
November 06, 2011, 09:08:41 PM »
good chance if you cut the plug off from the yard you will see where they go and the pretty colors.
1987,1988,1988,1990 samurai's, 1953 m38a1, 1996 x-90,blue.1996 x-90 red.1994 2 door tracker. only Dead Fish go with the flow. No Hairy Nosed Wombats were ran over on the trail today. My ZUK is Xenophobic.
talonxracer
1284
34
November 07, 2011, 06:31:46 AM »
There are two wires for that connector, the black w/white stripe is the excitation voltage and the white wire is for the charging lamp on the gauge cluster.
It could be the PO was intending to upgrade to a GM 12Si alternator.
Skyhiranger
3734
122
I don't buy, what I can build
Reply #3 on:
November 07, 2011, 06:53:35 PM »
The alternator plug is a big round green plug. Kinda hard to miss.
