Technical Discussion - Beginner / Repair
Can a 4dr 1991 engine & 5spTrans transplant into 1993 4dr auto??????
Mtn Wanderer
5
October 28, 2011, 09:44:09 AM »
Hi i want to transplant my 1991 engine and 5sp trans into a 1993 4dr JX that
has an auto trans 3sp with the over drive. can this be done reasonably?
I have heard I may have to change the complete wiring Harness Is this correct? or
can I just do the swap and change the ECM.
Does the wiring harness have any connection points that will help the swap??
any info will be appreciated.
Thanks
MTW
Skyhiranger
3734
122
I don't buy, what I can build
Re: Can a 4dr 1991 engine & 5spTrans transplant into 1993 4dr auto??????
October 29, 2011, 04:54:11 PM »
A 91 4 door has a 1.6 8V engine. A 93 4 door has a 1.6 16V engine.
You will have to swap the complete wiring harness and ECM. The wiring harness has sections that unplug, so that will make it a little easier to remove the old and put in the new.
Mtn Wanderer
5
October 30, 2011, 06:17:24 PM »
Thanks,
Sounds like I am in for a bit of work I'll be taking lots of pics before and while I dismantle the old one.
MTW
curreyr
2
Reply #3 on:
November 01, 2011, 07:35:45 AM »
I'd suggest you disassemble the entire dash in both rigs ...
Getting the 3 pedal assembly in/out will be one of the biggest headaches and I don;t even think it's possible without the dash pulled.
Having the dash pulled also aids tremendously in getting the harness(es) in/out.
