16v performance mods
  • 1659 Views
Offline airmanwilliams
  • 913
« on: October 18, 2011, 11:42:17 PM »
I just got rid of my sami and bought a more family friendly wheeler about 2 months ago which is a 93 sidekick  jx. Im wondering if there are any engine performance mods that I can do that will boost performance? I have thought about getting a performance cam from lowrange but wondered what else I might do that might even be cheaper.
Here are the specs so far for my rig:
Rebuilt 1.6 16v SOHC motor. [work done at Cleggs auto.]
Rebuilt Head, all new valves seats etc [work done at Warrens in Spanish fork. ]
Full Calmini Exhaust and headers
Calmini 3" Suspension Lift with 3" articulation lift and 2" body lift. Can run 33s without trimming
Calmini differential Drop Brackets
Recently tuned up Iridium plugs, Cap, Wires, and Rotor installed after rebuild.
CD player
NEW Stabilizer links
NEW Shocks
NEW Struts, Strut mounts
NEW EGR Valve
NEW Tie Rods [all around]
NEW ball Joints [All of them]
Calmini Drop Brackets
Upper Rear Ball Joint Spacer
NEW Front and Rear Brakes
NEW Vacuum Control Valves
NEW Valve Cover Gasket
New Timing Belt, Tensioner and Timing Cover
Custom Steel bumpers front and rear
Gas Tank has a Skid Plate.
Installed 5.625 Gears to match the 31" tires [$1000 gears if you can even find them] Speedo is dead on and the low range is lower than most 4x4s . These gears can handle up to 33 tires without killing low range gearing and highway driving.
Motor and head has less than 11K on them. Car has 156K
1993 4door Suzuki Sidekick JX
Re: 16v performance mods
« Reply #1 on: October 19, 2011, 10:23:14 AM »
You've  already done everything that's either easy or cheap, next is either forced induction or bigger motor. Or tune it to run nitro  :laugh:
Offline Jluck
  • 1389
  • 40
« Reply #2 on: October 20, 2011, 12:55:45 PM »
http://www.jgstools.com/turbo/thk.html
get out debit card before clicking on link...... ;)
  • 913
« Reply #3 on: October 20, 2011, 03:18:57 PM »
alittle spendy there. I have a friend that put a turbo on his samurai and will build the manifold and would only charge me for materials so I may go that route but have to research it some more with him and map things out.
« Reply #4 on: October 20, 2011, 04:44:56 PM »
Careful on the "cheapness" of a turbo build. Sure, anyone can slap together a turbo manifold and bolt a turbo to your engine, the difference being a cheap, corner cutting time bomb, vs a long lasting, reliable horsepower improvement.
