1995 geo tracker wont start?
  • 2912 Views
« on: October 16, 2011, 06:00:26 PM »
checked fuel pump good check pressure on rail good when you spray gas or either in it just quits when it burn all the fuel you sprayed in it 16v 5speed 4x4 1995
Re: 1995 geo tracker wont start?
« Reply #1 on: October 16, 2011, 06:04:45 PM »
You did check the obvious - gas in the tank?
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
« Reply #2 on: October 16, 2011, 06:18:30 PM »
yeah i m stumped it runs fine when you spray gas or either in like i said  maybe injectors are stuck any way to check
« Reply #3 on: October 16, 2011, 07:26:25 PM »
I just replaced the injectors in my Dodge Ram for $125, I bought the 4 hole Bosch units off eBay, took about 20 minutes to install them.  My fuel rail has a valve similar to a tire, I bled it and then pulled them out.  You could have cracked O-rings, my truck in an 03 with 80K miles and I changed them, it just restores power, I see a better fuel economy but before I had to spray starting fluid in to get it to run, must have been cheap gas or crap in the lines.  keep in mind carbureted vehicle's are relatively low pressure like 6 pounds, fuel injection can be 60 or more, I guess you could pull the rail, use clear water bottles and keep turning key on to prime them and see if any do not have a nice mist or if they leak.  I bought new ones just because I was getting single digit fuel economy now I get 13, that was about a 40% increase for the cost of a tank of gas, your in a much different situation than me.
Call them up - can't hurt
Free Telephone Sales/Tech Support |removethispart|@ 407-536-4509
Offline ranger88den
  • 279
« Reply #4 on: October 19, 2011, 07:05:06 AM »
Is the ECM signaling the injectors?  Mitsubishi was still using Rubycon capacitors in 1995.
http://www.kick-fix.com/ECU/ECU.html
« Reply #5 on: October 20, 2011, 03:38:18 PM »
changed the ecm had one on my parts cars runs good thx
Offline Soupy
  • 206
« Reply #6 on: October 20, 2011, 04:46:14 PM »
My first tracker was a 1995 4 door JLX. The previous owner spent $1400 swaping parts tracking down a starting problem. I ended up paying a guy $700 to track down a chaffed wire in the wire harness  two wires were chaffed and grounding out. If you have "done everything" it might be time to start swapping out harnesses as it appears you have a parts rig.
Offline ranger88den
  • 279
« Reply #7 on: October 21, 2011, 04:28:01 AM »
Talk about wires, check out this thread.  Kinda long, but interesting.
http://www.suzuki-forums.com/suzuki-sidekick-escudo-vitara-geo-tracker/48300-92-tracker-starts-but-wont-stay.html
