Are these Calmini Springs Shot?
  • 18 Replies
  • 4943 Views
« on: October 15, 2011, 09:48:01 PM »
The struts are obviously blown and we are replacing with cheaper Monroe Sensamatic and Dave's spacers from the UK but do these springs look like they may be collapsed?  When the truck is at a standstill the drivers side is a bit lower, the second you give it gas the front lifts about one or two inches and stays that way while driving.  The springs are rubbing powder coating off where they appear to be compressing fully, that is my reason for asking, should they have more pitch to them?  Please chime in...
« Last Edit: October 15, 2011, 09:51:00 PM by chevytracker »
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
Offline rascott
  • 669
  • 15
Re: Are these Calmini Springs Shot?
« Reply #1 on: October 16, 2011, 09:39:05 AM »
the spring looks compressed, as if you've jacked that wheel up at the a-arm?
i would think the bump stop should keep it from complete compression. mabe the strut was the bump stop?
mabe i'm not seeing the pic. right- if that is static load on the wheel, it looks collapsed to me....
« Reply #2 on: October 16, 2011, 09:50:57 AM »
It is a 95 two door sitting on the ground in pic and truck has 31's, both struts are Calminis and have oil all over them.
Offline rascott
  • 669
  • 15
« Reply #3 on: October 16, 2011, 04:05:59 PM »
mine is an '89, but the setup is similar(i think).
these are stock springs with pucks(jeff's) sitting on the ground.
your's don't look very springy.
i wonder how that happens?
re: blown struts- i blew my rear shocks by using them as bump stops. then i lowered the stops.
« Last Edit: October 16, 2011, 04:15:46 PM by rascott »
« Reply #4 on: October 17, 2011, 05:52:33 PM »
They kinda looked clapped to me. I went through a couple sets of Calmini coils before I found better replacemants. Probably not the fault of the coil though, the geometry of the coil mounting twists them in some unatural ways, that and they are progressively wound the first bit of travel being softer than the rest. They usually start to sag after coil binding awhile, and then just loose their tension. The struts are crap to begin with.
« Reply #5 on: October 17, 2011, 06:22:44 PM »
If the Ford F-150 front coils work I was going to get a used set, cut the end off and get them powder coated blue to match.  Then I will have imitation calmini coils to match all the other blue parts.
« Reply #6 on: October 18, 2011, 12:06:20 PM »
Or, you could try some Suspension Specialist 14" coils in the 550 rate available from FOA. $75 ea + shipping.
Offline rascott
  • 669
  • 15
« Reply #7 on: October 19, 2011, 09:42:18 AM »
i've been wondering if front springs from a 4door model would have more "spring".
do the calmini struts have a longer stoke?
« Reply #8 on: October 19, 2011, 10:16:50 AM »
The Calmini struts are just stock off the shelf units, nothing special.
Offline rascott
  • 669
  • 15
« Reply #9 on: October 19, 2011, 01:17:18 PM »
thanks
« Reply #10 on: October 21, 2011, 01:26:20 AM »
BRD HNTR modified his spring cup to straighten the springs out.  He had an issue with the bow being enough to hit the brake caliper on flex.
« Reply #11 on: October 21, 2011, 03:59:41 PM »
I did mine the opposite of BRD HNTR's, where he built up the a arm cup, I cut mine out so the coil would straighten out. Either way it's a good mod IMO.
Offline nprecon
  • 2318
  • 52
  • ONWARD... through the fog!
« Reply #12 on: October 21, 2011, 08:06:00 PM »
The first gen trucks have steel A-arms and the second have the cast A-arms.  I'm not sure you can grind/weld safely on the cast arms like you can the steel arms can you?
« Reply #13 on: October 24, 2011, 03:06:48 PM »
Cast what? iron, aluminum? either can be welded, but if it's an aluminum alloy it may be tricky.
Offline kreator
  • 634
  • 15
« Reply #14 on: October 27, 2011, 11:38:29 AM »
have you tried the FOA coils ? 550 x14  and are they 4" coils ?
