STUNT do you have MSN messanger?
So whats the differenece between the 2.5 and 2.7 outside? same size manifolds and so forth??
Also is there a secondary o2 behind the second cat?
JDMCRX, I don't use messenger.  Here is a quick run-down of the obvious visual differences (going from memory from last night):
* Exhaust manifolds are idential
* 2.7 intake manifold is taller near the throttle body and appears to be lacking an EGR like sensor on the left bank.  My 2.5 had California Emissions.
* The A/C compressor bracket is different, so I'll be moving over my 2.5 bracket.
* Power steering brackets are the same.
* Other pullies and the belt tensioner are identical.
* There are O2 sensors before and after each pre-cat, I don't believe there is a 5th O2 behind the main cat.
* Fuel line paths are identical.
* Misc sensors are different and in different locations.
* Oil pans are identical, so I suspect the 2.7 came out of a 4x4.
