tracker fuel guage /sender modification
  • 1926 Views
Offline Spitfire Rick
  • 123
  • fun lovin criminal
« on: September 27, 2011, 02:49:36 AM »
Ive got a 99 tracker project Im working on  Ive got a 4.3 /7004r  the gauges didnt work so i redid the gauge pod with spedo tach & a fuel gauge.the fuel sending unit is the stock tracker unit & reads 120 ohms =full 32.5ohms=1/2 3 ohms=full
the gauge I have  needs 240ohms =E ,103ohms 1/2,33ohms=F when the sending float is all the way down or empty the gauge reads over 1/2 tank I cant find a gauge that matched the sending unit specs  & if Ive got to modify something I want to modify what Ive already got
any one know of a way to add something like a resistor or ? or a aftermarket 2' guage that will work with my sender ?
If I have to understand don't bother explaining
Offline locjaw
  • 2045
  • 22
Re: tracker fuel guage /sender modification
« Reply #1 on: September 27, 2011, 07:42:38 AM »
i have a yard stick  >:D
have you discussed this with the gauge MFG? they might make a sending unit that can be modified. it's hard to beleive they didnt make a way(possibly inside the guage) to adjust those values. It seems like it would be simple to just have a resistance adjustment that would allow the top and bottom of the gauge to be adjustable, then the gauge would make internal adjustments for the range.
  • 123
« Reply #2 on: September 27, 2011, 09:43:11 AM »
the gauge I used was something I had but is comparable to a lot of gauges  I found this in the internet last night
       http://sites.google.com/site/shannonpowerlab2/home/calibrating-your-fuel-gauge
 Im going to look into this fix
