Toyota axles or D44 axles from a 78 wagoneer?
  • 1802 Views
« on: September 22, 2011, 02:46:55 PM »
I have a chance to get either stock yota axles for 250.00 or Dana 44 from 1978 wagoneer axles with correct drop front /rear. Not sure which way to go? Both are gonna be stronger than stock Sammy axles but not sure which is stronger between the two upgrades? Any suggestions
87 Sammie 1.3 myside 40mm CV carb,4.56 gears,locked rear,4:1 transfer case,yj swap with missing link,sittin on 31/12.50/15 swampers
Re: Toyota axles or D44 axles from a 78 wagoneer?
« Reply #1 on: September 22, 2011, 08:29:53 PM »
Really... No replies??
« Reply #2 on: September 22, 2011, 09:22:27 PM »
I say go Yota, it's sort of in the family, so to speak, they Aisin (sp)
make Suzuki Axles also, as well as the transmissions, they are a
division of Toyota
« Reply #3 on: September 24, 2011, 07:28:35 AM »
I don't know , Just saw an add in a 4x4 mag about a company that is making BOLT ON portal boxes for D44's that give you 4 inches of lift right there! Now that sounds very interesting.
Offline KJMac
  • 280
« Reply #4 on: September 27, 2011, 09:53:03 AM »
The Toyota will save quite a bit of weight! 250 for the yota's is cheap, I would go that route!
Where are you buying them? Around here in the Salem Or are the front is 250-350.
