Look like crank wobble? (Video)
  • 1694 Views
Offline zuki1018
  • 397
« on: September 22, 2011, 01:35:32 PM »
Hey folks.  I am battling an issue here with a related megasquirt issue. Long story.
Anywho, fresh shade-tree rebuilt 16v.  You may have to replay it a couple of times.  Look at the belt guides not the sprocket I installed.  I am wondering if this is typical pully wobble or if I should pull the engine and check things out.  Thanks for looking.
Re: Look like crank wobble? (Video)
« Reply #1 on: September 22, 2011, 07:00:08 PM »
I doubt the crank is the problem, I bet the pulley is
just a little tweaked, but they are thin so if you try
and tap it, you might make it worse
« Reply #2 on: September 25, 2011, 02:37:20 PM »
Check that the keyway is good and that the pulley is properly seated and then make double sure that the centre bolt is torqued correctly.
Offline zuki1018
  • 397
« Reply #3 on: September 26, 2011, 11:54:28 AM »
Thanks for the opinions.
