Whatever you do, DO NOT REMOVE THE BIG BOLT ON THE END OF THE CRANKSHAFT FIRST! Remove the 5 (or 4) bolts first THEN remove the big bolt IF IT IS ABSOLUTELY NECESSARY (ie. the big bolt is somehow damaged)!
Quote from: ack on September 19, 2011, 07:06:44 PMWhatever you do, DO NOT REMOVE THE BIG BOLT ON THE END OF THE CRANKSHAFT FIRST! Remove the 5 (or 4) bolts first THEN remove the big bolt IF IT IS ABSOLUTELY NECESSARY (ie. the big bolt is somehow damaged)! Ack,The BIG bolt. Is it lefty loosie, righty tighty? I was told you could break the bolt loose by putting a socket and breaker bar on it, then hit the starter. Sounds to me like an accident waiting to happen.
From kick-fix.com website
they forgot one hole in it for the locating pin.
