egr system
  • 2349 Views
egr system
« on: September 16, 2011, 11:20:20 AM »
hey there again guys!! so i got all my lighting fixed. and now the check engine light came on. ugh....no biggie tho i kinda like working on it. ha. so here is the deal. i checked the engine codes and it came back 51 or egr system. i was just wondering if there is maybe something i should check or tweek before i replace the valve? keep in mind i am not super mechanicly inclined with gas engines. but i can build a golf car from the ground up (electric). seems to transfer well though. thanks for all the info in advance. :)
Offline talonxracer
  • 1284
Re: egr system
« Reply #1 on: September 16, 2011, 11:50:43 AM »
Clean the EGR valve before purchasing a new one.
What engine do you have?
Re: egr system
« Reply #2 on: September 16, 2011, 12:50:13 PM »
its the stock 92 kick engine. i think the 1.8 8v. what would you reccomend to clean the valve?
Re: egr system
« Reply #3 on: September 16, 2011, 07:57:08 PM »
Brake cleaner or carb cleaner works pretty good for cleaning the EGR valve and EGR passages in the head and intake.  You'll need to use a stiff wire, or a broken speedo cable to run through the passages to break up the build up.
You can use a small screwdriver, to scrape the sides of the holes in the EGR valve.
You can use a small drill bit to clean out the little tube on the top of the EGR valve.  Just start with a small one and keep going bigger until you get the build up cleaned out with out actually drilling into the sides.
Re: egr system
« Reply #4 on: September 17, 2011, 01:35:57 PM »
I found these links to be helpful for addressing my EGR woes:
http://www.kick-fix.com/EGR-choice.html
http://bbs.zuwharrie.com/content?topic=27769.0
Good luck!
Re: egr system
« Reply #5 on: September 23, 2011, 11:30:25 AM »
thanks for all the help guys! job is done and truck runs like a champ!
Re: egr system
« Reply #6 on: September 23, 2011, 08:15:18 PM »
Cool.  Glad you got it fixed.
