Technical Discussion - Performance / Modify
sidekick transfercase rotate.
tracker14
September 10, 2011, 01:38:17 PM »
I have toyotas 3 linked under my kick and my pinion angles are still to much. im looking for the easiset solution to fix this now and i was wondering if anyone had rotated there t-case with a adapter plate to drop the slip yokes down.
Drone637
8121
116
Evil Cow
Re: sidekick transfercase rotate.
September 10, 2011, 06:53:14 PM »
Are you using a Toyota CV style drive shaft? If so you can re-do your rear axle to have the pinion point directly at the t-case. You only need to have the two level if your using U-Joints.
