CB Radio Mounts
  • 10 Replies
  • 2431 Views
CB Radio Mounts
« on: September 07, 2011, 12:12:40 PM »
Hey guys, does anyone have any pictures of cb's in their track/kick?
I was thinking about doing a smaller unit and trying to fit it in the ashtray slot but wanted to see if there was an easier/quicker way to install.
Also how did you run/mount the antenna?
Offline mike5721947
  • 545
Re: CB Radio Mounts
« Reply #1 on: September 07, 2011, 05:34:41 PM »
right now mine is setup to run with the 12v socket for power and a mag mount antenna. its ok, range sucks with the antenna (cheapy 24" walmart one) it sits next to my transfer case shifter under the ebrake. (cobra 19dx) looking at mounting it under the center console right infront of the shifter, needs some trimming for it to fit but it will be tucked nicely in.
cb is setup to be plugged in when needed. once i get ahold of a nice 48"whip its going next to the rear gate above the taillight, theres a cover there with 2 holes behind it im going to build a mount for.
31" kumhos 3inchs of lift.
Re: CB Radio Mounts
« Reply #2 on: September 07, 2011, 06:33:09 PM »
I thought about doing a plug-in set up, but I just figured I'd go ahead and run the wires since I'd be doing it for the coax any ways. I read a thread somewhere about mounting it on the center console, back where the rear ash trey is.
I was also thinking about one of those semi portable ones that can plug in like your talking about and then have a battery back to take out of the car with you.
And I've got a buddy with a magnetic antenna and his reception sucks also, i was going to do a whip.
Do you have a quick pic of where the cb is sitting now?
Offline talonxracer
  • 1284
Re: CB Radio Mounts
« Reply #3 on: September 07, 2011, 07:41:23 PM »
I just ordered the upper storage shelf from Damn Good Ideas to provide a perfect location to mount the CB.  http://damngoodidea.net/store/product.php?productid=4&cat=4&page=1
Re: CB Radio Mounts
« Reply #4 on: September 07, 2011, 08:34:48 PM »
Talon, how are you going to "hide" the coax? I was going for a clean mostly no wires showing set up.
That's a sweet idea though.
Offline talonxracer
  • 1284
Re: CB Radio Mounts
« Reply #5 on: September 09, 2011, 06:59:12 AM »
I will drill a hole in the windshield frame close to the mirror and run everything through the chassis. I have already run all the speaker wires up the pass side "A" pillar, through the upper door sill and then down the "B" pillars into the rear side panels. There is plenty of room for a coax cable to pass across to the drivers side, pass above the door, cross over to the pass side through the targa bar and down the pass side "B" pillar and back to the rear door.
Offline beagle..t
  • 1239
  • 16
Re: CB Radio Mounts
« Reply #6 on: September 09, 2011, 04:50:17 PM »
i mounted my cb where ther ashtreay goes and cigerette lighter was and then put a small piece of black plastic around it looks good and it works that was the best place for it
Re: CB Radio Mounts
« Reply #7 on: September 10, 2011, 09:55:23 AM »
You could go with a unit like the Cobra 75 where the entire unit is in the dash and all the controls are on the mic.
Offline talonxracer
  • 1284
Re: CB Radio Mounts
« Reply #8 on: September 12, 2011, 05:04:06 PM »
I received the DGI upper storage shelf and had it installed in about 2 minutes. I did need 2 screws that were a little longer to remount the mirror with the storage tray between it and the chassis. I will take a few pics when i get the radio mounted up.
« Last Edit: September 12, 2011, 05:05:46 PM by talonxracer »
Re: CB Radio Mounts
« Reply #9 on: September 25, 2011, 11:16:06 AM »
Thanks talon I'm excited to see how it looks, and how it works
Offline laserguy
Re: CB Radio Mounts
« Reply #10 on: October 08, 2011, 09:44:21 PM »
We just did a redesign for that tray, and will be including longer screws (sorry that you didnt get the longer screws with yours).
Visit us at damngoodidea.net for all your suzuki storage needs
