Needed : 89 Tracker Map Sensor
  • 982 Views
« on: September 04, 2011, 07:38:38 AM »
Got an 89 Tracker 1.6l 8v TBI,and the map sensor has went bad.
I scoured the local bone yards to no avail.
There is also another piece I need,but I am not excactly sure what it is.
It is cylinder shaped gadget that is held onto the throttle body with a stamped steel
bracket with two screws.Has two wires and it plugs into the same harness as the tps.
Anyone out there interested in swapping complete FI system or any Sammy / Tracker
engine parts [engine parts is my business] for a "bolt on" carb setup
weber / solex ?
Thanks
Randy
« Last Edit: September 04, 2011, 07:45:50 AM by tracker randy »
Re: Needed : 89 Tracker Map Sensor
« Reply #1 on: September 06, 2011, 08:27:26 AM »
el bump o ;)
