How much lift is too much lift?
  • 2040 Views
« on: September 02, 2011, 07:54:08 PM »
I just installed some OME springs from an XL-7 with 1 inch spacers into a 2001 Chevy Tracker (the XL-7's have a smaller top on front coils, but they fit).  I did not measure the distance in fender clearance before but now I have about 9 inches from the top of my almost 31's.  Is this too much, I was warned against it?  I also have OME struts with 2" extensions a 2" body lift and the transfer case/pan hard relocate brackets from the UK, plus truck has heavy add-ons front and rear.  Have not driven it yet, waiting for steering rack boots to arrive in the am then its off to find an alignment this holiday weekend.
Stock springs
OME springs and spacers
01 Tracker - OME Springs, 2" MK1 Body Lift, Warn 6K Winch, 18x9 Wheels, Rear Roll Cage and more.  95 Tracker with all Calmini bolt ons.  96 X-90 with mini lift and Super Swampers, this one has A/C and is an auto, nice.
Re: How much lift is too much lift?
« Reply #1 on: September 03, 2011, 12:35:16 PM »
One of the issues with a large lift is the front CV angle.  If it is to great you will break front axles when climbing in four wheel drive.
« Reply #2 on: September 03, 2011, 04:48:34 PM »
5 inch Drop
My springs collapsed today when i started engine and did a lock to lock turn.  The winch and mount most likely add 150 pounds but the OME springs were bought second hand so I am assuming they are the problem.
Offline DonD
  • 140
« Reply #3 on: September 03, 2011, 06:06:49 PM »
5 inch Drop
Looks like the rears are in the front and visa versa.
The front springs have larger diameter wire.
« Last Edit: September 03, 2011, 06:08:35 PM by DonD »
Central AZ
'90 Tracker
8k Smitty Winch
Man. hubs
Skids
Nerfs and sliders
Lockrite rear
OME susp
4.24 TC
ZOR Ft Bumper
Offline DonD
  • 140
« Reply #4 on: September 03, 2011, 06:14:46 PM »
Here's mine
Central AZ
'90 Tracker
8k Smitty Winch
Man. hubs
Skids
Nerfs and sliders
Lockrite rear
OME susp
4.24 TC
ZOR Ft Bumper
« Reply #5 on: September 03, 2011, 06:46:17 PM »
No way, I feel like a fool.
I swapped them out and now I have a mini monster
I have over 7 and a half inches clearance for now
« Last Edit: September 04, 2011, 05:11:46 PM by chevytracker »
