long travel struts
  • 61 Replies
  • 15572 Views
Re: long travel struts
« Reply #45 on: September 20, 2011, 10:02:53 AM »
It's the top end of a remote reservoir shock - something along these lines.
That's just a random image I pulled from Amazon - so that you can easier visualize it.
« Reply #46 on: September 20, 2011, 11:17:34 AM »
So the plan is to make a custom top and bottom mount for the strut and just bolt it in there?
Offline 96sport
  • 39
« Reply #47 on: September 20, 2011, 06:33:32 PM »
ya custom ends and lower sleeve, the last pic is just a mock up of lower sleeve. basicly same concept as the bilsteins or any other inverted strut.
« Reply #48 on: September 21, 2011, 07:01:41 AM »
I recognized that.  Are you using that little shock as a strut?  The other pics looked like you were custom making a strut with a very large shaft..
Offline 96sport
  • 39
« Reply #49 on: September 21, 2011, 06:22:13 PM »
starting with a 2 inch res shock. the body will be the "shaft". then building a lower section that is the "body" of the strut. this is how the bilsteins you guys are using are built. i am just going bigger and will have a shock that i can tune and rebuild when needed.
« Reply #50 on: September 22, 2011, 10:01:39 PM »
I loving this idea if it's full bolt on
How much wider will the front end up compared to a gv rear
I would love a tuff ifs that can show up all the big trucks
Offline 96sport
  • 39
« Reply #51 on: September 23, 2011, 06:39:09 AM »
yes it going to be totally bolt on. not sure what the gv width is but the track width will be 2.5 in wider per side
« Reply #52 on: September 23, 2011, 01:32:53 PM »
That makes it about 2" wider then a gv rear which shouldn't be to bad
Will ur new strut mount fit under the hood without a body lift and are they going to have a strut brace
What lift u aiming for
I would like to see atleast 4"
How r u setting the camber for the extra 2.5 with
R u just going to set the camber when u make the lower strut mount
Offline 96sport
  • 39
« Reply #53 on: September 23, 2011, 08:17:37 PM »
shooting for 4 inches of lift, no body lift. the upper strut mounts will include a brace. as far as camber the struts will have one of the holes slotted for adjustment, once set i will weld a heavy washer in place so nothing moves. i am building my sidekick for hauling ass in the rough so everything will be built very stout.
Offline blazin00
  • 17
« Reply #54 on: September 25, 2011, 10:30:20 AM »
Will this kit work on a 2000 2-door tracker?
Can you run a body lift if you want to?
Any ballpark guesstiment on what the price will be for a full kit?
Offline 96sport
  • 39
« Reply #55 on: September 25, 2011, 12:18:29 PM »
should be able to run a body lift with no problem. i am sure that there are differences in the 99 and up body style that will require its own kit. once mine is done i want to do the standard trackicks as well as the newer ones.
Offline kreator
  • 634
  • 15
« Reply #56 on: October 04, 2011, 09:31:50 AM »
Any new progress ?  ???
Offline 96sport
  • 39
« Reply #57 on: October 04, 2011, 05:49:20 PM »
i have most of the parts needed on hand but still researching the seal i need, loking like i will have to have them custom made. i need to spend some time on the lathe and it will be time to assemble these things.
« Reply #58 on: October 31, 2011, 02:46:01 PM »
Any progress on this yet
Offline 96sport
  • 39
« Reply #59 on: November 02, 2011, 08:16:02 PM »
unfortunately no, been crazy busy at work and working tons of overtime so not much time left for my projects.
