transmission help
  • 1100 Views
Offline Beastly
  • 15
transmission help
« on: August 25, 2011, 07:58:55 PM »
ok i have a 97 16 valve we finally finished the motor and wow is this thing a pain and confusing to work on. after we repaired the oil pan, brake lines and coolant leak i took it out for a drive and it wouldnt shift out of first now. idk why it shifted fine before and all the fluid is a great color and full. are these vacuum operated or electronically. thanks any pointers is appreciated
1993 Silverado
1997 Tracker
2003 Yamaha Warrior 350- fst 446 build
Re: transmission help
« Reply #1 on: August 26, 2011, 04:24:31 AM »
I think the 97 is a computer controller trans, but I may be wrong. 2 or 4 door?  3 or 4 speed? It makes a difference.
Offline Beastly
  • 15
« Reply #2 on: August 26, 2011, 04:39:51 AM »
its a 2 door and automatic
1993 Silverado
1997 Tracker
Offline talonxracer
  • 1284
« Reply #3 on: August 26, 2011, 06:21:26 AM »
Is the trans a 3spd or 4 spd auto?
You have a vacuum line mis-connected more than likely.
« Reply #4 on: August 26, 2011, 05:09:49 PM »
I agree with talonx, check your vacume line running from the rear of the intake manifold, just ahead of the throttle body, should be connected to the module on the trans.
Offline Beastly
  • 15
« Reply #5 on: August 26, 2011, 08:59:37 PM »
ah thank you awesome ill check that tomorrow
1993 Silverado
1997 Tracker
« Reply #6 on: August 27, 2011, 08:15:38 AM »
2 door=3 speed.
Yep, I agree, check the vacuum modulator connection, both at the engine and at the tranny (behind the pan).
Offline Beastly
  • 15
« Reply #7 on: August 27, 2011, 05:38:35 PM »
thanks a lot guys there was just a couple that were crossed up. i took it out on the quad trails
1993 Silverado
1997 Tracker
Offline talonxracer
  • 1284
« Reply #8 on: August 27, 2011, 07:09:31 PM »
Glad you were able to sort it out. happy trails!
