Ya, around here I see about $5 a hole to hone $15-25 a hole to bore, and
the head would be about $100-150 to regrind valves and surface and seals
or guides but your mileage may vary. They will check the line bore and the
crank and rods too, if they are within spec, I wouldn't do anything but replace
the rod bolts if you think they need it, I had rods resized for like $15 each
You will save $$$ if you do the take down instead of them doing it, but if
you want to have them do that they probably will, depends on the shop
