Master cylinder replacement
  • 1079 Views
Offline jow003
  • 403
« on: August 17, 2011, 01:50:53 PM »
Been a while since I posted a legit comment on here just lookin for some tech help.  I'm getting close to my project bein done and I need a new master cyl.  Upgrading to yota axles and the fact my old one was a bit leakey.  I have heard a couple ppl puttin stock ones from a lot of different cars.  What kind would work the best/would be the biggest I can use without modification on my 87 samurai?
Thanks in advance,
-O
BUY MY STUFF!! pm for details
87 Samurai...
5" SPOA/OTT -RRO
1.5" leaf springs-OME
RUF conversion-Trail Tough
1" shackles
33x1250x15 MTZs
15x8- DC-2s
Re: Master cylinder replacement
« Reply #1 on: August 18, 2011, 09:46:20 AM »
I'm guessing you are going disk in the front and drum in the back, I would try a four door sidekick master, the 87 should have the brakes in a x config. so your left front right rear are on the same cup(line) on the master, I would swap the lines under the passingers feet area and look for a proportioning valve from a 1990-1995 samurai for the rear to have one brake line, that should give you a big start.
