I have found a truck i want. As much as it pains me i have to let my sammi go. I dont need two vehicles that basically serve the same purpose.
1988 Suzuki Samurai soft top. 176xxx miles. Completely stock drivetrain. Everything mechanically works perfect on this rig. It has 2" shackle lift. Tires are 235/75/15 Mastercraft courser A/T's. The tire have less than 5K miles on them and have plenty of tread left.
Top is nuked and will need to be replaced if you want a full top. Right now it is kind of like a safari top. You can get a brand new top for 150 bucks online.
The body is great on this sammi. If you know samurais they rust out like crazy. There are three small places where the rust is bad and they can be easily fixed. The frame is solid.
The first owner of this little truck towed it behind his rv for over 10 years of its life. The engine maybe has 70 to 80 thousand miles on it and it runs fine. The only issue with this thing running wise is power, it doesnt have any. They only have 64 HP from the factory. Putting the slightly bigger tires on it didnt help with that. It goes great around town and on the country roads. However: If you are looking for a vehicle to run up the interestate this is not for you. I get around 25 MPG on average.
It has a cd player and decent speakers that work well. It is a 5spd manual and shifts fine and the 4wd works perfect.
I am sure I have forgotten some details. Just drop me a PM with any questions. Sammi is located in Weston, WV. Local pickup only please.
