Tracker/Sidekick removable door kit on Ebay
  • 20 Replies
  • 8409 Views
Re: Tracker/Sidekick removable door kit on Ebay
« Reply #15 on: October 07, 2011, 11:27:45 AM »
Don't you have to take the front fenders off to get at the hinges, or can you just get at the pins with the door open?
You should be able to remove the stock pins without removing the fender.  Then, I am sure you can take out the removable pins without removing the fender.
Offline MEDEL514
  • 52
  • Ramstein, Germany
« Reply #16 on: August 29, 2012, 09:57:59 PM »
I bought this kit because I was too lazy to go to the hardware store myself. lol  It works great, the only thing I don't like is that you loose your mirrors when you remove the doors, so I gotta figure something out for driving on the street without the doors.
90' Tracker
- with some goodies
« Reply #17 on: September 08, 2012, 11:42:07 AM »
How fumbly is it to take the doors off and put em back on? Can you do it alone?
Offline MongooseVRX
  • 64
    • M.O.S. forum
« Reply #18 on: September 11, 2012, 08:10:39 AM »
It's not too bad, I've done it a dozen or so times this sumer. The hardest time was 5AM in the dark, probably took 5 minutes.
1993 2-Door Tracker 1.6l 8v 5-speed manual hubs
Minnesota Overland
« Reply #19 on: September 12, 2012, 03:39:13 PM »
I replaced the factory pins in my rear door ( tintop tracker) with Grade 8 shouldered bolts, self locking nuts, and new bronze bushings all for under $13. But hey, I did actually have to drive to the local supply.  :laugh:  Do the doors rattle at all when put back on with that kit?
Offline chadstichter
  • 162
  • 98 4door home built coil yota swap 31s rear e-lock
« Reply #20 on: September 19, 2012, 08:39:11 PM »
i just found some hitch pins like the ones you buy at my house. it took me 10min to do all 4 doors and im 16 so its not that hard :P. just from building mine ive relized everything on these things isnt very difficult so far (nock on wood). i lifted mine by myself when i was 15 and put a new 1.6 and cluch
98 4door home built coil yota swap 31s rear e-locker, 8000lb winch and synthetic rope
|...BEER TRUCK..........| ||'|";, ___.
|_..._..._______===|=||_|__|..., ]
 l(|removethispart|@) (|removethispart|@)          l(|removethispart|@) (|removethispart|@)         l(|removethispart|@)
