Doggish Sidekick revisited
  • 1495 Views
« on: July 28, 2011, 03:21:23 PM »
Sidekick has been doggish for a year or so, intermittently. Sometimes it will run like a raped ape, others it is very slow on accelerating. This was the case with the stock tires as well as the 235/75 r 15s.
So I finally got around to checking the crankshaft keyway and it is beautiful. Good news and bad. I don't have to futz around with KB weld. Bad--well, I haven't found my problem!  It hadn't skipped a tooth either (it would have been consistently doggish if it did).
Suggestions?
Offline DonD
  • 140
Re: Doggish Sidekick revisited
« Reply #1 on: July 28, 2011, 04:10:58 PM »
YES, make sure to torque that bolt to 94ftlb!!
Central AZ
'90 Tracker
8k Smitty Winch
Man. hubs
Skids
Nerfs and sliders
Lockrite rear
OME susp
4.24 TC
ZOR Ft Bumper
« Reply #2 on: July 28, 2011, 08:18:36 PM »
Did you check the cam timing before you puller it apart?
could it be the cam is out of time a tooth or 2 causing the
sluggishness?
« Reply #3 on: July 29, 2011, 12:26:09 PM »
Wild,
It was spot on. I did advance the timing to 8 degrees btdc.  We will see how that works...
Dan
Offline ranger88den
  • 279
« Reply #4 on: July 29, 2011, 12:40:36 PM »
Did you freeze the igniton timing prior to strobe?
http://www.kick-fix.com/IGN_timing/IGN-FREEZE.HTML
« Reply #5 on: July 29, 2011, 06:43:42 PM »
Ranger,
Excellent link!  I will go ahead and adjust according to that page....
Dan
« Reply #6 on: July 31, 2011, 11:10:55 PM »
Ranger,
Adjusted the timing per the page you sent at 8* BTDC. It does run a little better.
