Gearing Possibilities?
  • 21 Replies
  • 3941 Views
Re: Gearing Possibilities?
« Reply #15 on: July 19, 2011, 05:27:06 PM »
they also have 4.30's from the newer rigs (99 and up) I know because I got a set from trail tough so I could drive on the street with the 6.4 t case.
4.30s can be found in trackicks as early as 94.
« Reply #16 on: July 19, 2011, 07:27:12 PM »
I did the exact same thing.
4.30 gears with 6.4 t-case.
Has me spinning about 4000rpm at 65 mph and a decent crawl ratio of 100:1
What size rubber are you turning with this setup ???
This could be good info to post for a real world comparison
Edit
I went and checked your profile and it shows you are running
31" x 12.50 Pro Comps
« Last Edit: July 19, 2011, 07:29:38 PM by wildgoody »
Offline my996duc1
  • 222
« Reply #17 on: July 19, 2011, 10:52:34 PM »
Edit
yeah, that is it.... on 15 x 10 rims with 2.5" bs.
Unfortunately Pro Comp no longer makes this tire in 31 x 12.50 so I will have to either switch tires or go to a 33 x 12.50 tire.
The 33" tire should drop me down to about 3800rpm at 65mph but that is just info from a gear calculator, not real world yet.
I like the 6.4 t-case. It has a good low range reduction and not as much of a high range reduction as some of the others.
Best of both worlds for a dual purpose setup.
1987 Tintop / 1.6 16V ps & ac / 6.4 t-case Twisted TT / 4.30 R&P Hybrid rear / Double Tough axles / Shrockworks all around / ARB f&r / Mighty Kong & TT full skid / DS disconnect / CV shafts f & r / YJ missing links f & r / Petroworks tintop cage / 15 gal Tank / 31" x 12.50 Pro Comps
Offline XEARLX
  • 62
« Reply #18 on: July 20, 2011, 07:57:37 AM »
Hey guys i came upon this the other day. Check it out
http://www.4lo.com/calc/geartable.htm
« Reply #19 on: July 20, 2011, 09:02:05 AM »
Ya, or like the link under all of my posts, in the tag line
http://wildcatent.freeyellow.com/zookmods/calc.htm
Been there for years
Offline my996duc1
  • 222
« Reply #20 on: July 20, 2011, 09:28:31 AM »
Here is the calculator I used when I was trying to figure out gearing.
The first one is great for comparing two setups side-by-side. They also have a few of the Sami combos already loaded in the tables. : http://www.grimmjeeper.com/gears.html
Here is another good table : http://www.lepayne.com/gears.html
« Last Edit: July 20, 2011, 09:31:47 AM by my996duc1 »
Offline XEARLX
  • 62
« Reply #21 on: July 20, 2011, 02:30:52 PM »
seems like they're all good  8)
