Alright... So i had a cranking but no start problem one morning, went out with my fsm and did some diagnostics, got down to a burned out igniter inside my distributor... (no movement of tach while cranking)... so i ordered a new distributor, i put the new distributor in using the instructions from the kick fix site...
1. bring #1 to 0degrees TDC on compression stroke (i can't blow air into the spark plug hole)
2. Mark #1 spark plug tower on distributor body
3. Install rotor on disty the correct way (rotor pointing toward long flat side of shaft)
4. Slide distributor into engine making sure rotor lines up directly with mark for #1 spark plug tower.
5. Install cap and wires (i know it spins counter clockwise, and i understand the firing order)
After i do all this i try to start but still have nothing(not even on test fuel), and no movement of the tachometer while cranking???
I put a timing light on the #1 wire and check timing while cranking and the timing is so far off i can't even see the timing mark on the pulley when the strobe flashes???
I have checked and re-checked EVERYTHING... Cam Timing, timing belt, valve lash, plugs, wires, cap, rotor, i have checked for shorts going to and from the noise suppresor, and also for a shorted noise suppressor... i have checked all my grounds and everything appears to be good, i don't understand what i could be doing wrong, all i can wonder about now is if it is my ecm somehow, but like i said i have the fsm and it doesn't point in that direction when i'm out checking things out, (i can get it to connect with my scan tool, and it seems to be sending voltage everywhere it needs to be) ANY help or ideas would be GREATLY appreciated, thanks guys
