Build up: 87 sami, 1.6 16v, Megasquirt
  • 52 Replies
  • 24394 Views
Offline zuki1018
  • 397
Re: Build up: 87 sami, 1.6 16v, Megasquirt
« Reply #45 on: February 12, 2012, 03:11:24 PM »
Here is a short summary of parts I used to install megasquirt:
     MS1 DIY kit                  203.00  (6-8 hours to build)
     8' wire harness               67.00
     Tuning cable                    5.50  (to use with laptop)
     Hall effect crank sensor    34.00
     36-1 trigger wheel          30.00
     DIY MS stimulator           45.00  (1 hour to build)
                             Total $384.00
If you have the extra coin you can spend about $150 and have MS built for you.
I opted out but I would suggest:
     DIY Relay board  64.00
     Relay cable         85.00
     (I used a sub fuse box and relays from my donor Tracker engine)
Other expenses with this engine swap:
     High flow fuel pump  + - 100.00
     Engine swap kit (motor mounts, engine adapter plate)  + - 175.00
     Heat shrink tubing, connectors, new clutch while your at it?
May as well call it about $600-$800.  You can also get a 36-1 wheel sprocket from a Ford XXXX in a scrapyard for peanuts.  It does not fit perfectly onto the 1.6 crank though.  I would suggest the few dollars to buy a sprocket, punch out the center, then weld it in place one you have established the hall sensor location on the correct tooth at TDC.  Its also possible to drill/tap then bolt the sprocket on the crank pulley.
« Reply #46 on: February 12, 2012, 09:25:33 PM »
Nice recap.  :)  A buddy is interested in a Megasquirt setup for a 350 with coil packs, so I pointed him over here to your thread.  :D
Offline zuki1018
  • 397
« Reply #47 on: February 13, 2012, 12:33:52 PM »
Well I origionally did a 4x COP setup.  I did manage to get it running/driving.  Its a bit more work with MS1 having to add additional drivers. I kept having RESET problems with this route and opted to go back to stock dizzy.  Actually my engine was missing the dizzy to begin with which is why i did the COP setup to start with.
Word to all.  I had a bazillion headaches using a VR sensor on my crank wheel.  VR's are very sensitive to electric noise and there seems to be several types (ground switching, going high, going low etc).  Do yourselves a favor and order a Hall sensor which is simply a 5 or 12v on/off.  Cut and dry and I have not had reset problems since.
Offline zuki1018
  • 397
« Reply #48 on: May 19, 2012, 08:34:36 AM »
Did a couple of short runs last night at 147Kpa (6.8psi)... screen shot is a first to second gear shift.  Thats a ball park of 115-130hp.  Such a huge difference from our old 1.3 carb!!
Next phase will be upgrading and possibly relocating the IAT sensor. Doing some heat shielding and installing a hood scoop of sorts.  Heat soaks a pain.... but doesn't impact it with the hood off!!
I love megasquirt.... definately forces you to learn a lot more about fuel injection.
« Reply #49 on: May 19, 2012, 02:42:43 PM »
[Word to all.  I had a bazillion headaches using a VR sensor on my crank wheel.  VR's are very sensitive to electric noise and there seems to be several types (ground switching, going high, going low etc).  Do yourselves a favor and order a Hall sensor which is simply a 5 or 12v on/off.  Cut and dry and I have not had reset problems since.
VR sensors are very reliable, the problem is usually bad PCB layout and decoupling on the interface. When the input is clamping there is a fair bit of current pushed into the supply rails which can cause ground shifts and noise spikes on a bad PCB, thats what usually causes reset problems.
Offline zuki1018
  • 397
« Reply #50 on: May 20, 2012, 06:57:13 AM »
Thanks for the info. You must be in a related industry?
Its very likely that the VR issues I previously had were specific to my situation.
« Reply #51 on: May 20, 2012, 01:51:51 PM »
I design ECUs for a large corporation based in Detroit  :)
Offline zuki1018
  • 397
« Reply #52 on: May 21, 2012, 07:19:32 AM »
Definitely makes you an expert!!
I think the Megasquirt 3 is a totally different PCB.  MS2 is a piggyback on to the same MS1 board.  They probably came a long way with the newer design.  ...although again, there are so many variables involved with a DIY circuit board build and then the external wiring install... others may not have the same issues I had.
